Which of these can a non-CORGI plumber do..?
So how much do we all charge to change a CH pump as long as the valves are shutting off and how much if you have to drain ?
Some charge an hourly rate, e.g. so much for the first hour then a lesser amount for each hour after that.
I charged my customer £40 for the job because he's a family friend (but he insisted I took £50).
Your very wrong mate !!
Fan is inside combustion casing so they cannot change it and they cannot touch the flue either !!
So for an example, i've just fitted a new version of an ideal classic. Not by choice, but i had to re-use the flue at low level as it's under a kitchen unit. To change the direction ot the flue you have to take the fan out and do varius other annoying time consuming thigs. Would they not be able to take the front of the boiler off? as this exposes the heat exchanger and burner, all though its not room sealed.
The answers still NO they cant take the front cover off !!
Did you fit a flue guard on this Classic if its that low ?
