Which screws do i use?
12 May 2010
Cardiganshire
With regard to my project re insulating my park home can i use wood screws to penetrate the softwood timber battens and the thin aluminium skin it has to go through as well?
any woodsrew will peirce the alley with little trouble
indeed when racking out vans they quite happily peirce the metal stays/supports
you need to work out the width and depth off the caravan frame before choosing screw size and length
depending how thick the frame is use dry wall (plasrerboard) screws they have a better thread for screwing through metal. if the frame is to thick to screw straight through drill a 2.5mm pilot hole first
