which timber for new floor?
12 Jul 2007
Yorkshire
I'm building an extension but I'm unsure as to what flooring material to use.
I was going to lay the lot in high denisity chip board flooring but a friend has told me that I should lay in marine ply in the kitchen.
This sounds like it may be overkill to me given there will be laminate/ tiles on top.
Do I have to lay in marine ply in the kitchen or would high density chipbaord/ T&G floorboards be fine?
thanks
pyj
pyjmis10 said:
thanks
pyj
Your friend is wise, if the washing machine floods you will need to replace the floor, as chipboard will go soggy like weetabix.
If you will be tiling then ply is a must, go for 25mm if tiling, 18mm if using vinyl/lino. Will be more expensive up front but will save loads of grief in the long run.
Marine ply is pricey, you can use standard wbp. (Weather & Boil Proof glues used)
Or you could use t&g, but will still need ply overboarding to get the floor flat for lino/tiles.
If you definately want to go the cheap route an duse chipboard then you should go for the bitumen coated type which will give it some added water protection.But if you can afford it then marine ply is best as said by Deluks
chipboard is rubbish
bargepole wouldn't touch I with it.
