P
paulv1972
Ok lets begin...
I have just removed an electric shower which from the supply came through a hager consumer unit with a 32 amp MCB it went up stairs to a 45 amp DP pull cord switch located in the bathroom then to the shower the wire is thick twin and earth grey cable i think it might be 2.5mm.
I now want to use this circuit to wire up my new whirlpool bath it says in the manual it needs a 230 V AC single phase 13A supply through a RCD not exceeding 30mA then fed via a double pole isolator with min gap of 3mm in all poles with 1.5mm cable.
Is the 32amp MCB ok to use and the pull switch and how do i use the 1.5mm cable from the whirlpool when the rest of the circuit is on 2.5mm cable?
