This post is not a "dig" as big_spark, I just decided to further clarify one of the points he could have explained better.
That's not true. If you only change one parameter in a circuit, the voltage, then as you lower the voltage the current will be lower (because the resistance is fixed).
Now, if you redesign your circuit with the goal of maintaining constant power, then if you lower the voltage you will need to lower resistance to have the same power. And it's here that the current will increase.
That's why a 1KW electric fire bought in the UK is only a 0.5 KW electric fire if you plug it in in the USA.
The current discussion of whether current or power kills is really 6 of one, half a dozen of the other.
If current flows through a resistance, power is dissipated. Flow a current through your heart, you flow power through your heart. You can't separate them.
HOwever, if you take a current sufficient to stop the heart, lets say 50 mA, if you were to double the current to 100 mA, you will dissipate twice the power in the heart. But you won't stop the heart twice.
Given that, I beleive it's more accurate to say that current kills. But it's both really, cos you can't have one without the other.
Big_Spark said:The Power in an electrical circuit is constant, this cannot change unless the parameters of the circuit are changed....
...Current cannot be changed unless either the resistance, capacitance, inductance or VOLTAGE in a circuit changes.
Lowering the voltage causes the current to rise, converseley increasing the voltage will cause the currrent to fall.
