Fook off!! Logs, a source of ignition and O2 is all that's needed !!
Odd, I've never head of a wood fire explosion.
And Gasbanni was being facetious Terry - at least I think he was.
But at the end of it, and in relation to the opening question, I think it's a Gonads thing as well; but I suspect the Gas safe guys know how to tighten them a lot more than HETAS does.
I was asked to build a website about natural forest practice, as part of this the owner wanted to tell people how bad burning wood was, but I was unhappy putting my name to the site without verifying what he was saying.
It really was an eye opener, tar build up, particular emissions, mean the burn has to be in two parts, extra air is inserted giving a very hot burn, getting this air is also a problem without causing a draft in the house or allowing items like tumble driers causing the burn not to fully remove particular emissions and also things like scrubbers, all too technical for me really.
However it seems until all the wood has be converted into charcoal the burn has to be at a very controlled rate, which in turn often means more heat than is required is released, there seems to be two main ways to get around the problem, one is a load of rock or concrete which stores the heat like electric storage heaters, the other is a liquid (water) heat store where the water heated is stored for use latter.
The price becomes silly for some of the systems, and there has to be a difference between using a small wood burner for some ambiance and using wood to heat the whole house. I am sure some one could tell you exactly what the installer has to check, but it is clearly far more complex to using gas or even pre-heated fuels like charcoal or coke.
I have probably forgotten ten times more than the Hetas courses teach.Spoke like a true ignoramus. 10 marks now put your dunces cap on.
That had more to do with sealing the water in than the fuel used.
iAnd that's the contradiction Gasbanni. Is it a faulty installation that causes the deaths (hence requiring an expensive course), or faulty burning of the fuel by the user of a good installation. The course's actually don't seem to be that expensive in comparison to Gas safe courses, and the Gas safe guys would argue that a faulty boiler installation can cause a gas explosion that'll take out a row of houses, but a solid fuel stove won't - even though you say that there are more deaths (percentage wise) from solid fuel stoves.
Well you've got me there; but you know that wasn't what I meant.
I refuse to be drawn! !Come on Terryfookwit what do you know about solid fuel ...nowt
Sorry Gasbanni, I really wan't being pedantic, and I have no wish to undermine you at all; you have my respect really, and I although you're post could have been a facetious one, I also realised how real it could be. With gas, it works, or stops, but you don't keep refilling it each time you turn it on, but there are time trying to get a stove going, that I think it's a black art, so yes, they need treating with a degree of respect.
