Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Screw terminals on soldered wires do become loose, the more solder ( thickness ) the sooner they become loose.
It is also possible that a loose terminal will over heat and melt the solder used to join the two cables in the terminal. When the power is removed the terminal will then cool and the cables and terminal are likely to become soldered together.
