Can anyone suggest why I get so little heat from my radiators. They are hot all over with no cold spots so i presume it is not a trapped air issue. i have however bled them all a little anyway.
They all get hot but the amount of heat that rises from them is not very much and it often takes several hours to increase the heat in the room by a couple of degrees.
The boiler is old, an apollo myson but seems to work fine. It is only a 1 bed house with 3 single rads and 1 double so i cannot see the boiler is underpowered.
The pipes that feed the rads are the smaller type (less than the standard 15mm)
Has anyone got any suggestions what the problem could be.
