Why would "a bit of bondage" be locked?
David, if Mr Sheds and Mr OMS treat you unfairly then just remember that one day you might be something.
Every Electrician that I have met agrees with every word I say.
I assume that when you say "met" you must mean personally and not via the forums (although I find even that explanation difficult to believe)
"Originally posted by: david911cockburn
OMS,
Do you mean P = (I x I) R:
If so why does this suggest to you that an increase in 'P' calls for an increase in 'R'?"
This was a "Classic" False Logic statement
ebee,
Do I need to do the maths for you?
V = IR therefore:
240v = 60amps x 4ohms or;
240v = 120amps x 2ohms.
Therefore P = (I x I)R
(60 x 60) x 4 = 14400watts or;
(120 x 120) x 2 = 28800watts.
The resistance is lower therefore the current increases along with the power!
I understand Ohm's law, and the relationships between current, voltage and power.
But I don't have the slightest clue what your point is in this thread.
echoes,
You are being asked to believe that during a fault of negligable impedance to earth the temperature of a cpc increases, but during this time the resistance of the cpc is increasing as the current flow is also increasing.
Which contradicts ohms law!
Although it's basically against my instincts to engage in this silly discussion...
You are being asked to believe that during a fault of negligable impedance to earth the temperature of a cpc increases, but during this time the resistance of the cpc is increasing as the current flow is also increasing. Which contradicts ohms law!
Yes, that would contradict Ohm's Law - but who is asking us to believe that the current would be increasing as the cable/CPC heats up (since it won't be)?
Kind Regards, John.
@cockburn Thankyou.
So, assuming that the cpc impedance has a positive temperature coefficient (like a tungsten filament in a light bulb). The relationship between voltage and current is no longer linear, because the resistance is not constant.
That does not contradict ohms law though.
@john - yes it is a silly (and rather basic, O-level one at that) discussion!
