- Joined
- 17 May 2012
- Messages
- 11,233
- Reaction score
- 961
- Country
So annoying, see a car that looks alright, and this is the MOT!
This is a dealer too.
https://www.check-mot.service.gov.uk/?_ga=2.23330682.1735383843.1616428136-2118400379.1612517607
Check mileage recorded at test, MOT expiry date, defects and advisories, and view test certificate
Date tested4 January 2021
FAIL
View test certificate
Mileage41,369 miles
MOT test number5605 0174 5407
Test location
View test location
Repair immediately (major defects):
Date tested4 March 2019
FAIL
Mileage41,354 miles
MOT test number3324 9113 4536
Test location
View test location
Do not drive until repaired (dangerous defects):
Date tested26 June 2018
PASS
FAIL
Mileage41,369 miles
Test location
View test location
- Exhaust has a major leak of exhaust gases front flexi (6.1.2 (a))
- Offside Stop lamp(s) not working (4.3.1 (a) (ii))
- Engine MIL inoperative or indicates a malfunction (8.2.1.2 (h))
- Exhaust carbon monoxide content at idle exceeds manufacturer's specified limits (8.2.1.2 (b))
- Exhaust carbon monoxide content after 2nd fast idle exceeds manufacturer's specified limits (8.2.1.2 (a))
- Horn not working (7.7 (a) (ii))
- Offside Rear Tyre obviously under inflated (5.2.3 (l))
- Central Stop lamp(s) non-obligatory stop lamp not working (4.3.1 (a) (ii))
- Nearside Rear Tyre slightly damaged/cracking or perishing outer sidewall (5.2.3 (d) (ii))
- Offside Rear Tyre slightly damaged/cracking or perishing sidewall sidewall (5.2.3 (d) (ii))
- Offside Rear Nail in tyre ()
FAIL
Mileage41,354 miles
Test location
View test location
- Stop lamp(s) remains on when the brakes are released lights are flashing (4.3.2 (a) (iii))
- Nearside Front Brake disc significantly and obviously worn (1.1.14 (a) (i))
- Offside Front Brake disc significantly and obviously worn (1.1.14 (a) (i))
- Supplementary restraint system warning lamp indicates a fault (7.1.6 (a))
- Exhaust has a major leak of exhaust gases from front flexi pipe (6.1.2 (a))
PASS
