wickes combi 102 problem
15 Mar 2009
hi, first visit here. Great forum. Could do with a little info if anyone can help.
My mother was recently cleaning our downstairs toilet room which is where our boiler is. She accidentally knocked something off the top of the boiler she described as a rubber nipple and a small valve like thing.She thinks this fell down the back of all the pipe boxing and can't be reached without removing the whole boxing. The boiler stopped working. My dad had a look inside the boiler and noticed an un-capped rubber pipe coming from a T leading to the hole where the rubber nipple poked out. He blocked this off with blue-tack as a test and the boiler worked perfectly again. Can anyone explain what we've lost and if our temporary blue-tack fix is going to cause any damage to our boiler? We no longer have our manual for the boiler either so were baffled. Thanks for your time.
Its the cap off either the flue sampling or air pressure test point.
Wickes boilers are made by Halstead if you email them they might send you one for free or at least say where you can get one.
The fact that it doesnt work without it or something that will suffice [blu tack] guarantees your safety in the meantime
