widl 126s error f04
29 Feb 2012
Yorkshire
Hi. wondering if any 1 can help me with error code f04 ,pressure switch stuck on empty, where is the pressure switch? if I'm getting this code is it best to order a new 1 from part master? :?
Under the lid on the right hand side at the top.
thanks rocks,yeah i found a picture of it on partmaster and sussed it . gonna just replace it . in your experience is that the solution?blew down the pipe and there is no blockage. tried twidling the screws thinking if it was jammed that might free it up , not so . what r the screws for does the posision of the screws have a bearing on the switch? thanks again
It can be one of two. Pressure switch or pcb , switch is the cheaper way. When you turned the screws it adjusts the fill prog more or less water.
