Will a proper grass roller make the difference?
30 Oct 2005
Birmingham
When I do my final cut I use my old green lawnmower with the roller on the back to create the lines.
Is it worth buying myself a proper steel roller or a modern plastic roller that fills with water to create more prominent lines or am I not really going to get that much of a difference?
Anyone use a roller after cutting?
The theory goes that the heavier the roller the longer the stripe will last.
So a good heavy roller mower should give good finish for at least 3-4 days, a water or sand filled roller like you suggest would be marginally heavier so should be a bit better but obviously an additional process to the cutting.
Your best bet might be to look out for a decent 2nd hand roller mower like an old hayter which you can use to cut and stripe.
