Current project had me swapping position of WC & bidet around, and fabricating new section of soil pipe to accommodate them.
As the existing pipe was solidly solvent welded with no free play, I took the hacksaw to it to remove a section, and in went (from drain end to vent end); 32mm boss for the bidet, solvent welded onto a stub of pipe, connected to ; 45 degree branch for the WC, then a section of straight pipe, connecting to another stub of pipe. As there was no free play, I connected the 2 pipes together with a coupler, cut lengthwise so's I could wrap it around the pipes, since I couldn't move the pipes to insert them lengthwise into the coupler.
It seems I didn't apply enough solvent cement to the coupler, as it was weeping a little when tested. I've thrown more solvent cement around the join, and will test again tomorrow once it's cured, but (to get to the question)
Any thoughts on how suitable silicone sealant would have been to treat the situation? I've put a wee dab of the stuff on a non-jointed section of the pipe, and I'll see if it's taken tomorrow, but has anyone out there used silicone on PVCu as an emergency measure or otherwise?
Regards, Graham
Regards, Graham
