    Dismiss Notice
Will the plane take off
Discussion in 'General Discussion' started by AronSearle, 1 Jun 2014.
  1. AronSearle
    AronSearle
    18 Nov 2011
    3,770
    Thanks Received:
    197
    Buckinghamshire
    Country:
    [​IMG]
    No cheating/googling.
  2. Sponsored Links
  3. Doug99
    Doug99
    14 Jan 2005
    1,463
    Thanks Received:
    146
    Glamorgan
    Country:
    Tip to the right - the ping pong ball is +ve buoyant, so it will have an upward force pulling on the left side to tip it right.
  4. Tips left a bit.
  5. ladylola
    ladylola
    19 Dec 2009
    3,314
    Thanks Received:
    289
    Staffordshire
    Country:
    Stay where it is, the steel ball is supported by the string transferring it's weight onto the frame. The Ping pong ball only acts on the water it's in and either way the mass of water stays the same in both flasks.
    Well that's what I reckon without looking but to answer the question , no the plane won't take off they don't run on water.
  6. AronSearle
    AronSearle
    18 Nov 2011
    3,770
    Thanks Received:
    197
    Buckinghamshire
    Country:
    Cough.
    Do you mean someone could literally pull themselves up by their shoelaces?
    The upwards force is within the beaker itself, it does not produce and external upward force.
  7. I thought the same but then thought the trick was that the left ball was introduced first??
  8. Norcon
    Norcon
    17 May 2008
    8,417
    Thanks Received:
    357
    Country:
    Same weight on each side so it stays balanced.
  9. doitall
    doitall
    8 Jan 2005
    19,003
    Thanks Received:
    1,538
    Bath
    Country:
    The magnetic attraction would tip the scale to the left :LOL: :LOL:
    Or the water on the right will be heavy than the water on the left so it will tip to the right.
  10. Sponsored Links
  11. JBR
    JBR
    9 Jan 2007
    9,017
    Thanks Received:
    395
    Cheshire
    Country:
    It stays where it is. The weight (mass) of each container of water remains the same, even though some water is displaced by the balls it still remains in the container. There will be a very slight increase in weight in the left container due to the ping pong ball and string, but I think that would be negligible.
  12. ladylola
    ladylola
    19 Dec 2009
    3,314
    Thanks Received:
    289
    Staffordshire
    Country:
    Just a rethink.
    The weight of the steel ball is taken by that frame it's suspended from.
    The Ping pong ball excerts force on the water but it's mass and that of the string is supported by the water thus making the left hand flask slightly heavier , assuming identical masses of water . Wether the ball is in the position shown or simply floating on the surface it adds it's mass to the left hand side thus that side should tip down a bit.
  13. enyam
    enyam
    24 Sep 2011
    2,248
    Thanks Received:
    42
    Devon
    Country:
    Stays the same,isn't the clue in the question,the volume of the balls are the same.
  14. Tips to the left, both ping pong ball and steel sphere displace the same amount of water, but the ping pong ball adds a small amount of mass to the left hand side, whereas the steel ball adds no mass to the right as it is independently supported.
  15. Norcon
    Norcon
    17 May 2008
    8,417
    Thanks Received:
    357
    Country:
    Tips to the right (steel ball side) as the buyount forces on the left are cancelled out by Newtons third law.
    (Source for that answer = google)
  16. snico
    snico
    28 Aug 2004
    2,533
    Thanks Received:
    11
    Cheshire
    Country:
    Correct, and tips to the right with some force too
  17. joe-90
    joe-90
    28 Oct 2005
    31,283
    Thanks Received:
    1,063
    Country:
    My right ball hangs a little lower than my left ball.
    However, in the experiment the water displacement is the same in each beaker so the beam stay where it is.
    • Thanks Thanks x 1
Loading...
Share This Page
