    Dismiss Notice
Will the plane take off
Discussion in 'General Discussion' started by AronSearle, 1 Jun 2014.
  1. Norcon
    Norcon
    17 May 2008
    8,417
    Thanks Received:
    357
    Country:
    I actually watched it on U tube with the steel being lowered quickly into the water thus exerting a downward force.
    If the experiment was carried out with the balls in place before the water is poured then I think it will remain balanced.
  2. Sponsored Links
  3. Dextraneous
    Dextraneous
    23 Jun 2013
    2,617
    Thanks Received:
    81
    Manchester
    Country:
    nope. Tips left.
  4. Norcon
    Norcon
    17 May 2008
    8,417
    Thanks Received:
    357
    Country:
    Air has some weight so in theory it should tip to the left.
    Plus the weight of ping pong ball and string.
    If the balancing is equal before water is added then it stays equal.
  5. jockscott
    jockscott
    14 May 2013
    2,179
    Thanks Received:
    99
    East Lothian
    Country:
    As long as the diameter of the ping pong ball and the steel ball are the same, then the scales will remain in balance.
  6. snico
    snico
    28 Aug 2004
    2,533
    Thanks Received:
    11
    Cheshire
    Country:
    Tips right
  7. JBR
    JBR
    9 Jan 2007
    9,017
    Thanks Received:
    395
    Cheshire
    Country:
    Don't worry Joe. That is quite normal.
    The right kidney is normally slightly lower than the left because of the presence of the liver. The testes are part of the same system (genito-urinary) and the right one is also slightly lower too. I believe it's a developmental thing.
    I still think the beam would still remain in balance, though, or possibly tip very slightly to the left - with or without the presence of your balls.
  8. doitall
    doitall
    8 Jan 2005
    19,003
    Thanks Received:
    1,538
    Bath
    Country:
    The weight of the ball will be transfered to the water/glass, unless you go down far enough to achieve weightlessness
  9. breadnbutter
    breadnbutter
    25 Feb 2011
    3,805
    Thanks Received:
    649
    Bedfordshire
    Country:
    the answer is staring right at me, you posted it at 6.10 pm, its now 23.11 and it has not moved.
    • Thanks Thanks x 1
  10. Sponsored Links
  11. Brigadier
    Brigadier
    14 Jan 2008
    9,912
    Thanks Received:
    773
    Staffordshire
    Country:
    One knacker hangs lower than the other, so that they don't bang off each other while you are walking. :eek:
  12. JBR
    JBR
    9 Jan 2007
    9,017
    Thanks Received:
    395
    Cheshire
    Country:
    Mine don't. I carry them in a wheelbarrow whenever I go anywhere.
  13. Brigadier
    Brigadier
    14 Jan 2008
    9,912
    Thanks Received:
    773
    Staffordshire
    Country:
    Ahhhh - you're the bloke off the telly - "The man with the 10st tentacles."
    :mrgreen:
  14. jeds
    jeds
    16 Apr 2004
    4,750
    Thanks Received:
    641
    Country:
    Both balls add equal buoyant force to the beakers. So the sum of the forces is zero. But the scale would tip slightly down to the left by the weight of the ping pong ball and string. If the scale was sensitive enough.
  15. JBR
    JBR
    9 Jan 2007
    9,017
    Thanks Received:
    395
    Cheshire
    Country:
    Oh dear, I am undone.
  16. Brigadier
    Brigadier
    14 Jan 2008
    9,912
    Thanks Received:
    773
    Staffordshire
    Country:
    I think Norcs is close to the money there.
    In the video, the guy "lowers" (drops, more like) the steel ball into the beaker, causing the balance to tip quickly down on the RHS.
    My guess - if the ping pong and steel balls are both in place before the water is added, the balance will obviously tip to the LHS (weight of ping pong ball + string > weight of steel ball hanging into the beaker, which is zero).
    Add equal weight of water to both beakers, LHS is still heavier.
    Lowering the steel ball in will exert a downward force on the RHS beaker, until it stops (by the string fully-supporting its weight, and not by coming to rest on the bottom of the beaker); the balance will then tip back to the LHS.
  17. jeds
    jeds
    16 Apr 2004
    4,750
    Thanks Received:
    641
    Country:
    There's a much easier way to visualise it by subtracting all equal factors. The beakers are identical so take them away. The water - and the amount of displacement - is identical so take the water away. What's left is a suspended ball - which adds zero downward force to the right. And a ping pong ball and string - which adds a small downward force to the left. So the scale tips to the left.
Loading...
Share This Page
