Hello,
I'm in the process of changing all my radiators which are supplied by pipes which come out horizontally from the wall. I need to add a drain off valve to each radiator as they are drop fed from upstairs.
I've seen this https://www.screwfix.com/p/drayton-...gclsrc=aw.ds&dclid=CO7KwZnC3NgCFY0TGwodxFYA_Q
tail piece from Drayton. Unfortunately if you use a non-Drayton TRV (they don't do any angled versions), the thread on the valve side does not fully screw into other makes lockshield valves.
Before I order a job lot and start fitting them, is it likely to seal properly?
