Wilo Pumps
payne166 said:
Hands on hearts guy's, what pump would you choose on your own systems if it went pear shaped?
My own pump failed about two months ago, and I fitted a Grundfos UPS 15-50.
If I knew my own system was totally clean then I would fit a Wilo.
The Wilo has a plastic bearing that quickly gets worn badly by fine magnetite. Otherwise the electrical part virtually never fails.
The CP53 seems to be a good all round pump at a lower price. They both wear the bearings and fail electrically.
The Grunfoss has a ceramic bearing and a VERY hard shaft which is very resistant to wear BUT it costs about twice as much AND they have a much greater chance of failing electrically.
I have not seen enough DAB pumps and would be interested to hear of anywhere they have been used in quantity to see how reliable they are. I would not normally think of fitting them because they look cheap.
Tony
Agile said:
The Grunfoss .... they have a much greater chance of failing electrically.
My memory is pretty good, and I can remember only one Grundfos that I've replaced that had failed electrically instead of simply being worn out.
I fitted a Wilo in place of a Grunfos and the chap is begging me to put a Grunny back; it's in a bedroom cupboard and the Wilo is noticeably louder.
Had 3 electrically failed grunnies since Xmas, one was full of water though.
My local scrap yard is selling Grundfos pumps (or any make) from old combis for £2.00. You know it makes sense. Always have a couple of 'recon pumps' for sale.
Presumably you have them hanging from the inside of your overcoat and sell in them yer local.
