Window lock stuck!
9 May 2009
Manchester
I'm not having a lot of luck with windows this week!
A bathroom window (small, horizontal top outwards opening) has stuck locked. The handle turns smoothly but the window remains locked.
From the movement of the pane, it feels like it's unlocked on the left but the right remains firm.
I've taken the handle off and the spine looks fine and turns the mechanism 90 degrees as it should but the right hand side won't budge.
I can't see anyway of getting to the inside of the pane to try and sort the lock. Any ideas?
Thanks in advance.
Phil
Gearboxs most likely need replacing.
Diy is possible but depends on your skill level and bravery.
1st start with a window that works (assuming they are all the same make) and is easily accessible inside and out.
Open it and take the handle off, Then go outside and remove the gearbox by taking out all the screws. Take photos of the gearbox and note down any codes and stamps on it then put it all back together. (Give it a good clean and lube while your at it, Silicone spray is best)
Google the codes or post the pics here and you can order the gearboxs for however many windows you need.
Next getting the window open. The smaller they are the trickier they are to do.
Take out the glass, Open the handle then remove it.
Then with tools like flat screwdrivers and flat scrapers you need to force them in the side between the sash and the frame, Then wiggle and bend the sash side to side at the bottom edge while pushing the unlocked side out with one hand.
Eventually the sash should force open and by now you already know how to fit the gearbox.
Read more: http://www.diynot.com/diy/threads/upvc-window-handle-not-working.431817/#ixzz3ZoYIhpkJ
