I have a number of double glazed window that do not open.
I have had this before and a builder friend managed to fix it.
I am not sure how he did fix it but he basically took the glass out and somehow got to the mechanism. Sadly I didn’t watch the rest. A metal part had snapped so it was only unlocking the top part (or the bottom – can’t remember).
Once he replaced the metal strip it all worked.
I can’t contact him (I have tried) so thought I would give a shot.
I took the glazed panel unit out but clearly there is more to it than that.
I can’t get to the mechanism, so I suspect I need to somehow get the window open to access the broken bit and then get a replacement.
From the photos you can see that this window is unlocked at the top but not the bottom.
Photos of the latches (on another window) show they drop into metal channels so a simple wiggling in an “L” shaped thingy to flip the lock up would work would it.
Also on the big window I looked at there are 4 sticky out locking things with 2 quite central so there may be 2 to shift (although I assume they would be linked). Also there is a prong that sticks out to further secure it.
Not sure what to try but willing to have a go. The worst that could happen is I end up having to buy a new window here. But if I sus it, I can fix this and the other 2 that have broken in the same way.
Any ideas?
Any ideas?
