Hi all,
I've got two (top- opening) windows which seem to have dropped so much that their bottoms scrape on their (fixed) frames. I have been told that, over time, the weight of the opening window causes this. However, though one of the windows is approx 1M2 the other is approx 15x8cm. Surely weight wouldn't be a factor with the small window?
Can anyone confirm if this is the likely cause and a possible solution?
I was thinking of experimenting with the small window by opening it fully, removing the screws holding one of the hinges to the frame, and then lifting it up a touch before drilling new holes and securing at this slightly higher level with self tappers. Rinse and repeat with the other side. Is this likely to work or is it a stupid idea?
Not sure this is a viable approach to take with the larger window though. The weight would probably preclude such an approach and it may be better to remove the window altogether and fit new hinges which would I would be confident to do if the flat were not on the second floor.
Removing the sealed glass unit from the window surround is not an option either as the windows are externally glazed.
I guess I may have to call the professionals in, what do you all think?
