We run an energiser for electric netting around the hen run. After a few years some of the connectors are getting ropey, and the insulation on the wires is becoming UV degraded and brittle. Can anyone suggest the best sort of wire to use for this purpose, and a good supplier? The cables that need to be replaced are ..
Supply to/from the solar panel, around 500mA @ 14V
Earth from the HV side of the energiser to the earth rod
Output from the HV side of the energiser to the fence - this one carries the pulses of 5 or 10kV.
There are also +ve and -ve cables to the 12V battery, but these are undercover so protected.
The important characteristics would be long life outdoors, flexibility, and compatibility with standard crimp terminals so I can put the right ring or fork terminals to suit.
I thought maybe test lead flex would be appropriate, but I'm not sure how that would stand being outdoors. I also wonder about voltage rating for the output cable, but the original from the manufacturer looks to be perfectly ordinary PVC insulated equipment wire, nothing special either for the high voltage or for exterior use.
Any suggestions or comments welcome,
Thanks, Tony S
Thanks, Tony S
