"The results of our tests were disappointing. Although most of the devices could find copper pipe under floorboards, only three could spot pipe behind plasterboard."
"And results for wire detection were patchy. None of the detectors could satisfactorily spot wire or live current we'd hidden below relatively thin 10mm plasterboard. Although several manufacturers claim their models are capable of detection at this depth, our test results suggest you should be wary."
