Wire wall light to plug
9 Nov 2016
I'm considering purchasing a couple of wall lights for the bedroom, and just wanted to double check what I was planning on doing was fine.
I want to connect these using external wires to a plug (fused with 3A) which I'll then plug into the socket nearby. I intend to use a grommet (probably actually something like this) to ensure the cable doesn't get damaged where I have drilled a hole in the casing.
Would this setup be something that is ok, or is there something I've missed here? (Also would it be ok to wire both lights to a single plug, or should each be wired to a separate one)
Cheers
Personally, I hate to see wires dangling down a wall.
But otherwise your plan looks ok. Plug needs a 3A fuse.
Make sure you use 3-core cable if those lights need an earth
I'm with TTC on the dangling cable thing.
But there is a bigger problem, probably, with your idea - a cable clamp/restraint inside the light. It's made to be attached to your fixed wiring, so it will probably not have any way of clamping the cable, but it's got to have one if you wire it using a loose flex as you plan to.
Separate - plugs are not designed to take multiple cables.
Why not just do it properly?
The grommet I intend to us has a strain relief clamp.
It's just an option I'm considering, and it would be to make a feature out of the wiring rather than it just been wiring running down the wall.
Ah - OK - I didn't look at the link to what you said you'd use.
Grommets:
"Wiring running down a wall" is wiring running buried in the wall, not seen at all.
