- Joined
- 9 Nov 2016
- Messages
- 17
- Reaction score
- 0
- Country
I'm considering purchasing a couple of wall lights for the bedroom, and just wanted to double check what I was planning on doing was fine.
I want to connect these using external wires to a plug (fused with 3A) which I'll then plug into the socket nearby. I intend to use a grommet (probably actually something like this) to ensure the cable doesn't get damaged where I have drilled a hole in the casing.
Would this setup be something that is ok, or is there something I've missed here? (Also would it be ok to wire both lights to a single plug, or should each be wired to a separate one)
Cheers
Cheers
