Wired doorbell push
1 Mar 2010
Londonderry
Hi all,
I've got a mains powered wired doorbell in my house and the push button stopped working recently after it all went a bit rusty. I bought a replacement online which is illuminated (the original one wasn't).
The transformer in the loft is rated at 8v 0.5amps and the packaging for the button says 8v 2amps. I decided to wire it up anyway as its only a low voltage system and it all works fine including the light.
My question is, will there be any chance of me damaging the transformer by using a 2amp rated switch on a 0.5amp transformer?
Thanks in advance :)[/list]
I assume they just mean the switch is rated to switch up to 2 amps which is ample for most bells
If it was the lamp that needed 2amps then it would be a problem, though thats unlikely
Usually the lamp is wired across the two terminals same as an unlit version and takes hardly any current.
When operated the bell sounds and light goes off
I agree should be ok
FYI that's just like worrying if you'd damage something weighing 50kg because you'd put it on a shelf which could support 200kg.
