Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I have an alpha combi with a built in mechanical clock (useless) I want to replace with a wireless programmable room stat. what do i do with wires to old clock
Apha do a built in Wireless Programmable Roomstat, whereby the receiver fits into the panel where the mechanical clock used to be, and you use the existing wiring.
dont bother with a wireless stat all of these are crap. as other wireless items get better over theyears they tend to interfere with the stat and it becomes faulty (ie my house the doorbell could turn the boiler on for a hour) a customer i have worked at many times her next doors wifi turned her boiler off if the connected it to a laptop
this all happened because the changed the radio signal and yes the roomstat will say it uses its own rf but it doesnt its bs plus you keep needing new batteries which in some stats if you dont put them in quick enough it messes the boiler up and it needs reprograming i even had to ring the breakdown engineers once cause the customers changed the battries
