Wireless Programmable Thermostats
27 Nov 2007
Manchester
In an attempt to make my current heating system more efficient (combi boiler with just temperature control on the unit) I would like to install a wireless setback thermostat control system.
I need it to be a digital timed thermostat which incorporates a 7 day programmer for heating the house at lower levels during unoccupied periods and during the night, then increase the temperature for when I'm home.
I'd essentially like as much control as possible over the boiler to be as efficient as possible. I don't want to pay silly money for it though - £50 to 70 would be ideal.
Couple of questions:
1. Can anyone recommend any particular product to suit, from experience of using them?
2. The boiler I have is an IconT combi boiler, so it's not one of your common mainstream units. Are the wireless thermostats a universal fit, or does the boiler have to have an input for a thermostat control?
Thanks in advance, guys
Chris.
Ok, had a good look around and found a couple I'm interested in.
I've had a look at the Salus RT500RF, namely because of its relatively low price tag and it seems to do most things that I need. However, I noticed that some do not actually switch the boiler on and off like a regular mecho-timeclock would - you can only set a range of temperatures throughout the day.
I guess you could turn the temperature right down, but surely this means you would be wasting energy powering the circulation pump, as the boiler would still essentially be on, just not firing?
Is this something inherent in cheaper models, or just something I should look out for?
The Honeywell CMT927 seems good but you certainly pay for it.
Cheers,
Chris.
Ok, had
Cheers,
Chris.
Fantastic thermostat .I fit them all of the time and they are worth every penny.
Heating controls online do them delivered for just under £100.
Treat yourself.
I always fit the Siemens REV23RF, Excellent product and looks the part as well. Unbeatable price available HERE
Wow, that is cheap considering it's price elsewhere. Didn't spot that one.
I think I may stretch my original budget and go for one of those.
Cheers for that :cool:
