I'm looking to put a wireless thermostat onto a Gloworm ultimate 40bf which is gravity hot water. To get the central heating you need both the heating and water turned on. I was wondering if it was possible to wire it so that when the thermostat calls for heat it turns both on and likewise turns both off when heat is satisfied?
The current programmer will be getting replaced at the same time, so if the above is possible, any recommendations on a programmer and wireless stat to do this job would be great.
