Wiring a 48 Hour Time Clock
The way I understand it is you need to be able to isolate locally to the immersion heater element(s) which is why DP 20A switch isolators are used to feed the heat resistant flex which feeds the immersion heaters.
So I fit the Isolator between the immersion and Timer switch instead of having it before the Timer switch.
Makes sense.
