I have used this site before and found it very informative so thought Id ask another question.
I'm installing a log cabin for use as an office in my garden which obviously needs power. To facilitate this, I am installing 6mm 3 core SWA connected to the main consumer unit via a 40amp mcb with a 40A 30mA RCD in the cabin consumer unit which will run a lighting circuit at 6A (1.0mm twin and earth) consisting of two flourescent tubes and a ring circuit at 32A (2.5mm twin and earth) with approximately 8 double sockets.
The SWA cable will be buried approximately 600mm with a total run of approx 30 meters.
I have been measuring my current voltage and ampage draw for a number of months and they are very low so my question finally is, have I done my calculations properly and chosen the right cable and MCB/consumer unit setup?
Thanks in advance for your advice,
Chris
Chris
