Hi All,
I replacing my old fluorescent kitchen light with new one, however I can't work out the wiring for it.
In the light ceiling mount is a 3 screw terminal block (L,N,E) which connects to the Earth and ballast/tubes L and N terminals.
From the ceiling I have 3 sets of 2 core (+earth) wire. Two of the earth's were pre wired (in one shield case), so i know these are the from (the livingroom) supply and too (the bathroom) supply.
The third 2 core cable is just for the light switch.
With only 3 connectors in the terminal block and no switch terminal, I can not work out how to wire it up.
Does anyone know how to wire into the terminal block with this configuration?
Oh and before you ask, I didn't get to see the old wiring before the light was taken down by my plasterer but that one also has the same 3 terminal block connector and that definitely worked.
