I need some help on if this is safe or not...
I want to fit a power shower, but to run the cable to my fuse box means i will either I have to make A LOT of tracks in my wall which will make a big mess be very time consuming and ill have to plaster. Or use very ugly trunking.
My question is.... Outside my bathroom is the boiler cupboard with the main switch to turn the boiler/hot water/heating on and off. If I change this switch for a split RCD plug socket/switch can I then use a 3 pin plug on the shower and it still be safe????
Hope this makes sense thank you
