Electrical connection
Please observe national standards, the
regulations of your local electricity supply
company as well as data the rating label.
Wiring diagram (Fig. 9)
1 Ground cable connector
2 Signal lamp
3 Thermostat
4 Temperature fuse with reset funktion
5 Heating element
6 Temperature fuse
* For voltage and current information, please
refer to the rating label.
The connection cable can be stored in to the
cable compartment provided (Fig. 10). If the
water heater is to be connected permanently
to AC mains circuit (connector socket), an
isolator with at least 3 mm separation on all
poles must be used.
SN 5 S und SN 10 S:
The unit must not be installed with fixed
connection cable.
These are from the manual...... is it saying it should be installed with a plug? I was going to intall it with a fused spur. Also what size flex and fuse does one need for a 2kw heater as it doesnt mention fuse sizes?
2 Signal lamp
3 Thermostat
5 Heating element
6 Temperature fuse
poles must be used.
SN 5 S und SN 10 S:
connection cable.
