Wiring advice.
The only way you can go wrong now is if there is a fourth terminal in your thermostat. I've had a quick look on the internet for data but I can't find any. If there is a fourth one it'll be for the contact that closes when the temperature rises. (You use it for cooling, not heating.) The 1% danger is that somebody has connected the third wire to this one rather than the proper neutral terminal. :shock: :shock: :shock: The answer lies in that mini diagram inside the stat cover. :) :) :)
There is a Termianl 4 in stat but its not being used.
The wiring inside stat has never been touched.It was working old boiler so i know that side is ok.
I'm just hoping we got the 2 lives correct at the boiler end.
Thanks for your time .. :) :)
