I am fitting a cabinet with lights in the bathroom over the sink. The walls are plasterboard and I want to run a cable to the shaving socket but it is flush mounted so trunking is out. Can I run cable behind plasterboard and is it a big job?
That depends greatly on the specifics of your location, on how much effort you'll have to put into learning the things you need to know if you don't already, and in which part of the country you are if you want to do it lawfully.
