hi i have 8 flood lights that will be used in the garden with 22w low energy bulbs in. can i wire these in a daisy chain? inside each light is a connector block, would the best way be to wire in and out of these?
i should of said, the electrician has wired outside (about 6 foot past the back door under the decking) and from what he has told me there is a connector which i can connect my armoured cable to.
two gland armoured cable - prob not. what would you advise in using?
the lights are just £5 standard Homebase floodlights, the kind people put on the drives. would i need some kind of connector?
i was thinking of using pond cable in an armoured tubing? is this legal/ok to use. only reason for that would be cheaper to lay and install.
STOP right now, you obviously don't have a clue, get your sparky back to put them in for you or risk burning down the house or electrocuting the next person to walk up your drive..
