I'm after a bit of guidance please.
I have a pair of latern style outdoor lights that I want to put either side of my front door. I don't really want cable or conduit visible either inside or out if I can avoid it. The hall way will be replastered in a few weeks, so chasing etc not a problem, but obviously I want to get it right beforehand!
Internally on one side of the front door there is a ring main socket with the wiring chased down from the ceiling. Can I drill straight through directly next to this ring main to the rear of the outside light fitting, and then chase it up the wall internally to the ceiling void? My thinking is that it will be in the safe zone vertical from the socket further down the wall, or is this a no no?
The other side of the door, there will be a stud wall (not yet built) coming off the inside of the external wall at 90deg. THe light switch for the outside lights and the hall light will be mounted in this wall. Can I come straight through the external wall into the side of the stud wall either to the switch directly (depending on next questions), or up into the ceiling void with the switch cables. I'm guessing at best I would have to come throught the external wall at the same height as the switch to put it in the safe horizontal zone of the switch?
With regarding putting switch for hall and outside lights into the stud wall, what is the correct method of running the cables? I assume they should be in some sort of conduit, not just floating aroudn with the insulation.
Finally what would be the best way of wiring up the pair of lights and switch? I can get power feed from the downstairs lighting ring in the ceiling void. I'm thinking use a juction box and wire as per a ceiling rose, running T&E to each of the lights.
many thanks
many thanks
