I’m planning to renovate my kitchen, the walls are in a bad state and I will replace the old lath and plaster with 18mm ply to give good solid walls that are easy to fix units to.
I plan to run plastic conduit behind the ply for all circuits, keeping the conduit in safe zones. I’ll probably use 35mm metal back boxes for all switches, sockets etc
The thing I am stuck with is the wiring to the lights under the units. I want plenty of light onto the work surface but am not sure what is the standard method, or best method of getting cables to theses lights. (In the existing kitchen there is a 1.5mm t&e supply that emerges from the wall a few centimeters below the bottom of the upper units. I am sure there must be a better way but I’m unsure what it would be so would appreciate your advice. I think that using conduit future proofs it as I can run ELV or LV now and it could easily be changed in future. I’m in a top flat so the conduit will go up into my loft.
Any recommendations for good under cabinet lights would help, I am sure I’ll use LEDs as I hate the existing fluorescents that have aged to be different shades of light.
I’m doing the wiring myself. I changed the consumer unit last year and have enough RCBOs fitted to supply the lights, ring, oven and hob.
