Around 10 years ago I replaced the single ceiling light fitting in our kitchen with 4 flush fitting halogen downlighters. I used properly rated wiring and installed the fittings in series from the original ceiling fitting. I obtained the fittings and GU10 50w bulbs from Screwfix and soon began to have problems with the odd bullb blowing - probably about one every month or so. After I had used a pack of 5, I complained to Screwfix and they sent a free pack.
Over time these also failed and I bought two packs of 10 from an Internet supplier.
I now find I have used about half ot these GU10's - a lot of the time it is the same fitting that the bulb fails in, currently for the fourth time in a couple of months in one fitting. I always check the wiring and the supply at the fitting when changing bulbs and thins are always fine. It seems as if there is somehow a build up in the circuit which eventually blows a bulb.
Any ideas?
Tony
Any ideas?
Tony
