Wiring in a light with 3 core and earth
27 Aug 2020
Trying to wire in a light outside for a one way switch, but the cable is 3 core and earth (brown, black, Grey, copper) and the light only has 3 terminals L, N and E. Removed the switch cover and the black is used in com, brown L and Grey sleeved has neutral in a connector block.
How do I correctly wire in the light?
Grey with blue sleeve is the neutral
Either brown or black is the switched live, need more detail on the switch. I guess there’s another cable coming to the switch? Where does that connect. maybe the blue is connected to the grey on the 3-core? Where does the brown connect?
a picture writes a thousand words.
Yeah black I assume is being used as switch live as it is in the COM terminal. There is a another cable going into the switch as there is two grey cables in a connector block and two brown cables in L in the switch. Unable to get photo atm
Well, that ain't normal, as the COM really should have the two browns in it and the black should be in the L terminal. But it'll work OK as it is,
Therefore, the black is the switched live to the light (should have a brown sleeve on it), grey with a blue sleeve is neutral. The bare conductor should not be bare, it is the earth. It should have a green/yellow sleeve both ends, be connected to earth at the switch and to the E terminal at the light.
I see, that’s where the confusion is. So to confirm
Grey with blue sleeving in N terminal
Bare copper with earth sleeving in E terminal
Brown and black with brown sleeving in L terminal?
NO. You only need the black (switched live) to the L on the light. The brown (permanent live)is not used and needs to terminate in a separate insulated terminal block of some sort.
the black OR the brown could go into the L terminal.
We can't tell from here without a pic of the rear of the switch
