- Joined
- 9 Nov 2014
- Messages
- 5
- Reaction score
- 0
- Country
Hi there,
I intend to wire up 3 appliances, 1) air pump, 2) water pump and 3) the led lights. To do this I will join or common up the two pumps under the bath and run a single cable through the wall out to the kitchen. Here I will replace a double socket which is a spur off the main with one 13amp FCU for the pumps. This FCU I will connect to another 3 amp FCU, via cable from the main in on the 13amp FCU to the main in on the 3amp. Obviously the two pumps will have one cable from the 13amp, and the lights a acble from the 3 amp. Ok, so just a few questions on this.
1) Is this acceptable, as I won't be running anything else via sockets etc of the spur.
2) For connecting the wires under the bath, are standard non waterproof connectors OK, being under a paneled bath and elevated off the floor. The socket ring is also RCD protected.
3) Are there any other considerations I have missed.
Many thanks in advance
