Wiring my garage
21 Apr 2006
Help. I am trying to bring power into my garage, but I am a little unsure about the best method.
There is a dedicated cable (6mm I think), from the main circuit board in the house, and it has its own breaker, fuse etc...
The cable comes into the garage, but then stops, I want to use this to bring power to the garage. I am thinking of a couple of strip lights and a few double sockets for things like lawnmowers etc..
I am not sure if it should be a ring main or radial etc..
Any advice would be appreciated.
Thanks :D
You're aware this work is notifiable to your local council's building control?
You should terminate the end of that cable in a 2-way consumer unit, with an RCD (if there isn't already one at the house) Then run a 16A radial to some sockets, and a 5A lighting circuit.
What sort of cable is used? and where does it run?
No I wasn't, but I shall take care of that.
The cable runs from an RCD in the house, to the garage. What do you mean by a two way consumer unit. With just one cable running into the garage, do I have to fit an RCD at the garage end of the cable with two differently rated fuses, 16A and 5A and simple run the radial to some sockets and the lighting circuit?
The cable from the house is approximately 6mm square and runs underground. It was installed when the house was built in 1993.
Thanks for your help
The "RCD" in the house - does it have a test button? Or is it really an MCB?
MCB:
RCD:
The cable - does it have strands of steel wire around it like this:
Or Does it run in metal conduit? One or the other is fine, but twin and earth - normal cable - is wholly unsuitable for burial.
And a mini consumer unit:
(the RCD can be replaced with a main switch if it transpires that you DO, in fact, have an RCD at the house!)
Thanks for the helpful pictures. The cable is connected to an RCD in the house, at the garage end of the cable, there is nothing but the exposed cable. (I have isolated the circuit). The cable is just like the one in the picture, with the shielding wire around the core of the cable.
Brilliant advice.
I have now completed the work, and have power in the garage. The most important thing though, is that it is safe.
Fitted all the necessary circuit breakers etc.. correct wiring.
Thanks for all your help
Best Wishes :D
