I have to replace my uncle's two port valve on his pumped CH and gravity hw system. As the thing is about 40yrs old I'm sure there will be wiring problems. Can you tell me how many wires there will be, and what they do, thanks
What?!honeywell .... no microswitch
What?...just wish the rest of the system wasn't posessed!
You don't need a priest, you just need a systematic approach to solving the problem.replaced motorised valve, downstairs rad feeds now red hot but HW circuit not flowing (22mm pumped, back boiler).
That's not strange - there should be three pipes. However...the strange thing is, going thru the chimney stack into/out of the boiler are 3 pipes
This should be 28mm. Are you sure it's 22mm?22mm hw rising to the cylinder upstairs...
WHAT?!...with a 15mm teed off n going down under the boards for CH flow
What makes you think that this is a return?a 15mm CH or HW return (not sure which)
and another 22mm which is a return cos it don't get hot, but god knows what that does.
How did you achieve that?Ive now got the HW working
Then shut off the downstairs rads and turn the pump up to maximum.I think the downstairs rads work, upstairs definately don't
