Wiring question Ideal Logic Plus and Salus RT500RF
4 Mar 2012
Yorkshire
Good afternoon,
I have recently moved into a new house which has a Ideal logic+30 combi boiler and Salus RT500RF timer/stat.
The problem I have is that no matter what I set the thermostat to the boiler, when central heating is turned on, it simply does not go off. The boiler runs constantly no matter how high or low I set the thermostat. I've even tried turning the stat off completely but it still runs constantly. The only way to turn it off is by twisting the knob on the boiler back to hot water only. This means when I have the central heating on I'm running up and down the stairs every half hour to try and maintain an ok temperature, not really ideal.
Anyway as I've said I tried everything and done done checks. The thermostat panel is 'talking' to the receiver upstairs. I know this because if I turn the thermostat to a higher setting than the room is at the small heat call light comes on on the receiver and on the thermostat panel. If I turn the temp below the current room temp the green heat call light on the receiver goes off. I've also changed the batteries just in case, read that on here can sort some problems. Sadly though the thermostat will not control the boiler at all.
I think the receiver isn't talking to the boiler because they aren't connected together by any wires. I opened up the receiver today and it is connected to the mains but the three other terminals - NO, COM and NC are not wired to anything.
Inside the boiler there is a link wire between the 'thermostat' connection and 'timer' connection from reading the install manual I've found it suggests that this gives a permanent heat call to the boiler which would explain why the thermostat doesn't control the boiler. I removed the link wire to see what would happen and basically if the boiler setting was put to water and CH the CH would not come on at all, this is what I expected because without the link wire nothing is telling the boiler to come on , I.e. no heat call.
Looking in the manual I believe the receiver should be connected to the boiler. Looking at the manual I think I need to connect 'COM' on the receiver to the 'STAT' connection in the boiler and 'NO' on the receiver to the 'TIMER' connection in the boiler.
Does anyone know if this is correct?
Could I do any damage by giving what I think is right a go?
Would really appreciate any help on this one.
Alternatively should I just call a plumber? Could I be missing something?
Thank you
Steve
has the link been removed for system ctrls
Good afternoon,
Thank you
Steve
