I needed to move a 2 gang switch to the other side of the doorway which I have done successfully. But I would like to understand why the wiring is as it is.
The left hand switch is the last of three that controls the hall lights – three downlights and three wall lights just above the skirting board. It isn’t the intermediate switch.
The right hand one controls the porch infra-ray security light (which is set to switch on when someone is on the doorstep or when we go out).
There are four cables inside the pattress. Cable 1 consists only of a brown which goes to L2 of the hall switch. The blue is cut and there is no earth. All the other cables are earthed to the metal pattress box. Cable 2 has a red to L1 of the hall switch and a blue that is joined to the black of cable 4 in a terminal block. The yellow of cable 2 is loose and has brown tape round its end.
The red of cable 3 goes to L1 of the hall switch, the blue to L2 and the yellow to the common.
The red of cable 4 goes to L1 of the PIR switch and the black meets the blue of cable 2 in the terminal block as described above.
A brown wire goes between L1 of the hall switch and the common of the PIR switch.
It all works – but can anyone explain what is going on?! I've attached a diagram (I think).
http://www.diynot.com/network/Malcolm258540/albums/
Many thanks.
Many thanks.
