Wiring sockets - mystery wire....
18 Jul 2008
Fife
I am asking this here, as the chap that roughed out my electrics in my new extension is on holiday for the next fortnight.
I am connecting the socket face plates in the kitchen.
It is a radial circuit
Each double socket has either a loop (two wires) coming from the wall, or a single wire (end of the run)
Fine
Easy - i can cope with that!
However, one of the boxes has a loop and a single wire protruding from the wall.
It is definitely not one of the isolator switches for appliances. THey are all accounted for.
Any ideas?
My thought is that the loop may be a free end, and that just in the wall it comes to an end. Probably looked fine until they sheeted everything leaving this mystery.
I am loathe to start tugging stuff to see what happens, though..!
What sizes are the conductors? Have you got a photo you could upload?
It will be pure guess work for anyone without at least that and probably with it too
ideally wanted to avoid a two week wait...
so checked here in case there was anything obvious to a seasoned spark.
As it is, i'll probably wait.
It is all 2.5mm, i think
Sounds like it could be a spur, say to a socket higher up for a cooker hood or something, but I would advise you wait.
If you HAVE to connect them up, my suggestion would be to safely terminate this rogue cable into a connector, taped up, in the back MAKING SURE it's not exposed. Once thats done you can connect the rest up as normal..
If the cable is a spur then you'll find something not working, but if the cable is a feed or becomes live for any other reason then it would have been made safe. If this does happen, safely isolate and start again etc.
If you do this, however, you MUST remember to get the sparkie to identify this cable and either use or remove it when he returns. Don't jut leave it there.
But I advise you wait :roll:
thanks.
what is confusing me is that all the spur points are identified (washing machine, extractor hood, dishwasher, hob & tumblydryer) and this is a mystery extra one to nowhere, and a pencil mark to say 'double socket' and it is where i asked for it.
.....i'll wait!
sparky had agreed to let me spend the time wirig all sockets and switches, but leave all the face plates hanging loose for him to inspect prior to screwing the face plates in.
but, i'll wait on this one!
my latest opinion on this is that as this is a radial circuit, and this is a central socket near the main run, the cable from the CU arrives here, and there is a wire off to the left, and a wire off to the right, hence three wires
make sense?
