Hello, just a quickie. My oven is rated at 3.1kW. About 14A. The manual says it needs a 'minimum fuse of 16A'
My cooker circuit is currently 32A MCB > 6mm cable > 45A Cooker Switch > 6mm cable > Cooker Outlet Plate > 1.5mm 3 core flex > 16A oven.
Would it be safer for me to change it to
16A MCB > 6mm cable > 20A DP Switch > 6mm cable > Cooker Outlet Plate > 2.5mm 3 core flex > 16A oven????
Or any combination of the above?
Does it matter that I have a 45A switch? Is 1.5mm cable enough?
As a side note, I am also planning on adding a fused spur from this ring to power the ignition on a gas hob, so a 5A fuse?
Thank you.
Edited with the right cable description
Thank you.
