Wiska Box Seals
30 Oct 2003
Worcestershire
I am looking at putting some SELV lighting in the garden - 12V LED driver in the garage so no worries about that side - but some lights will be supplied by one cable to then split near their destination
My question relates to the self-sealing WK 116 type boxes. Is the seal satisfactory or would a different box with a gland be recommended?
The trouble with that particular box is that there is no strain relief on the cables, something that a gland would offer.
Wiska make outdoor JBs with threaded entries, so you have a choice of just poking the cable through, or screwing a gland in.
Avoid top entry, as water is more likely to enter.
Indeed.
In the case of SWA (or similar), I personally favour side-entry, since if one uses the bottom, water can possibly run into the cable and corrode the armour.
Kind Regards, John
Indeed.
Kind Regards, John
Also drill a small drain hole at the lowest point to enable any moisture which does get in, as it will, to escape.
Ah! Not thought about strain relief especially as the cables could be tugged whilst in the garden - some cables will be laid on the surface to the light. TLC seem to have some sort of strain relief gizmo for the boxes but not sure how well it would work. I have also thought that some flexible conduit might also be worthwhile to give a little mechanical protection so glanding would be the natural choice
When i done my garden i concreted in stumps of wooden fence post about 300mm high with hand made hardwood caps on top, the boxes were mounted on them.
Seems to be the trend now to fill boxes with electrical jelly and bury them, which i suppose is fine if done good
It would be adequate to clip the cables (firmly) to the wall/post/whatever close to where they enter the box (more than one clip per cable!).
Kind Regards, John
That might work in my garden. I will have some 3" x 3" posts replaced later this year and I could re-use those and would look better than just lying around!
