I have a downstairs toilet which wobbles about when someone is sat on it.
After having a look at how the base is held down, I noticed that it seems have four screws and not bolts! I put a Phillips screwdriver into a couple of them and the screw just spins around.
So I am a bit unsure what fixings I should use to secure the toilet to the concrete floor. Should the people who installed the toilet have used bolts instead of screws?
If so, how should I go about removing and reinstalling the toilet as I have not done this before and don’t want to end up with water all over the place
Also, if I need to use bolts, how do I know which ones to get?
Any help would be appreciated.
FYI.
The toilet discharges the waste out of the rear of the toilet and has a water feed pipe that is quite long from the cistern back to the toilet.
Please see the photo's below which should explain further.
Close up of screws in toilet base
Another view of screws in toilet base
Overview of toilet
View of rear of toilet
[/b]
FYI.
Overview of toilet
